0 members (), 47 guests, and 0 robots.
Topics128,050
Posts1,055,641
#565058 08/14/2009 8:18 PM
I am rebuilding/re-arching my rear leaf springs and I am about ready to put them back on. I noticed that I had a spacer on on side, passenger I think and now that I got the springs back its missing. Do I need the spacer? Do I need one for both sides? Where can I get them?
My searching for a vendor and info on the spacer has been fruitless. Al help is appreciated! The spacer was the size of the axle perch and about a 1/4" thick I think.
58' 3200 235 3-speed/OD
Piece of 1/4 plate and drill a hole?..................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
My '54 3100 has a spacer on the rear right side. It is part of the side mount spare option to offset the weight of the tire and carrier on the drivers side. The spacer is 1/2 inch thick. Tom
Was it tapered, could have been a shim to adjust pinion angle?
Otherwise if all you want is a apacer just make it.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
It wasnt tapered, so it sounds more like Tom's explaination to me. I appreciate the info fellas!
