0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | I am rebuilding/re-arching my rear leaf springs and I am about ready to put them back on. I noticed that I had a spacer on on side, passenger I think and now that I got the springs back its missing. Do I need the spacer? Do I need one for both sides? Where can I get them?
My searching for a vendor and info on the spacer has been fruitless. Al help is appreciated! The spacer was the size of the axle perch and about a 1/4" thick I think.
58' 3200 235 3-speed/OD
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Piece of 1/4 plate and drill a hole?..................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: May 2009 Posts: 11 New Guy | | New Guy Joined: May 2009 Posts: 11 | My '54 3100 has a spacer on the rear right side. It is part of the side mount spare option to offset the weight of the tire and carrier on the drivers side. The spacer is 1/2 inch thick. Tom | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Was it tapered, could have been a shim to adjust pinion angle? Otherwise if all you want is a apacer just make it.
Grigg | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | It wasnt tapered, so it sounds more like Tom's explaination to me. I appreciate the info fellas!
