0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56541 02/15/2006 1:15 AM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Hey guys does anybody know if the 41 3spd trans in a 1 ton is the same trans used in the 1/2 ton? Thanks George | | |
#56542 02/15/2006 1:40 AM | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | George, the 1941 3/4 ton used the same 3-speed as the 1/2 ton. As for the 1 ton it had a open-drive line both front and rear (2-piece) and wasn't available from the factory with a 3-speed. | | |
