| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56538 02/14/2006 8:09 PM | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | I'm trying to find a source for an original front mount. I bought one a while ago and while it would work, it required changing the hardware setup. I went ahead and reused the original since it was not torn, but all the years in oil haqven't done it any good. In fact, I still have a weep of oil at the base of the timing cover among other places. I've not seen an old engine dry as a bone but there have to be some tricks. Thanks in advance. | | |
#56539 02/15/2006 12:31 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What is this 261 engine in?
See the USA in your vintage Chevrolet! My Blog | | |
#56540 02/19/2006 1:18 AM | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | Pre68 dave: The 261 is in a 62 chevrolet lwb. It is the original engine from the factory, an option only that year. The mount is in the front attached to the plate by the timing cover and a tab on the front side of the crossmember. | | |
