| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I got the truck out on the highway today. First itme after install of the HEI I got 61 MPH out of a 53 3600 with a 216 and foru on the floor.
I was very impressed. I did a vac check and the gauge needle is shakey. I think that means valve issues. I will ruin it a lot int he next few weeks to see if they are just sticky form sitting. If no improbement I will look furthe rinto adjustments and sela replacement.
Any thoughts on this? Any chance this will improve on its own?
Rich
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | excuse me ...seal replacement not sela replacement | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Another fun typo: you say you will "ruin" it a lot in the next few weeks!!! What a shame. Is this your subconscious mind talking?
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | I don't know if I would run a 216" at 61 mph just for the fun of it or not. Probably not. As for the rough idle, shakey vacume guage issue, why not run a warm compression check to see what result would be? | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Already did the compression check, not bad all cylinders are between 110 and 120. I thionk this is sticky valves or valve related in some way, seals, springs or adjustment.
This run was not a full press. I am sure if I pushed it I could have gotten more out of it with the over sized tires.
I am trying to work many years of sitting in a field out of it and have gradually taken it to this level ove the last several monhths.
There are many on this site who have taken these trucks even further than this.
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | The needle shaking on the vacuum gauge seems better. I advanced the timing slightly and get a reading of 21 on the guage.
The gauge reading drops rapidly on quick acceleration but recovers to 21 then rises to 25 or so on deceleration then stabilizes again at 21. I assume this is normal as it makes sense.
any thoughts on vacuum readings?
