0 members (),
207
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 6 New Guy | | New Guy Joined: Jul 2009 Posts: 6 | Found an old rear bumper for my 1951 chevy 1 ton, but was painted and looked rust, but straight and solid. Would need to be chrome plated though. Is that better or should I really not waste my time. Also looking for a place around Chicago and suburbs that does good chrome plating if that is my route to take. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I try to rechrome the originial parts as it seems the steel was better back then. Some of the new stuff is pretty cheaply made. JMO | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | 1 ton used a thicker gauge metal than a 3/4 ton and are not available through repop. If yours is indeed an original 1 ton, I would have it rechromed. | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | My experience so far says if you have an original piece that can be restored and re-chromed -- do it that way. Have had not so good experiences with repop pieces compared with restoration of original parts. Dale | | |
