6 members (Gdads51, tclederman, DannyW, treegrower, baldeagle, 3B), 72 guests, and 6 robots.
Topics128,014
Posts1,055,328
Members48,419
#564524 08/13/2009 1:43 AM
I am rebuilding the front axle on my 1950 3100, and I ran into an issue on the spindles. I am using spindles from a 1954 3100, and the upper bolts holes where the backing plate mounts to the spindle are a different size than the 1950. The spindles from the '50 have larger upper holes on the spindle (7/16"), while the '54 spindles have (5/16" I think). Why the difference?
TexanC3 #564530 08/13/2009 1:55 AM
The 1950 brake system (Huck Brakes) is significantly different from the 1954 brake system (Bendix Brakes). The backing plates, spindles, and other and brake system parts are different.
I found that when I went to inspect my brakes that one side had huck brakes and the other bendix, which lead to my axle rebuild. I have all the components for the bendix brakes now.
Should I swap the spindles then with the ones with the correct size rather than drill the holes out to a larger dia?
