6 members (sron48, 55shaker, Bill Hanlon, Lightholder's Dad, JW51, Forty9), 196 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#562790 08/07/2009 3:48 AM
hello. I have a 66 chevy c10 - with stock rear end and 350 with 350 transmission. At 65mph its running at like 3500 rpm. I'm looking for a change that will allow me highway driving. But i'm looking for bolt on. I don't want to make drive train changes. So is it best to change the gear ratio or get a different transmission. Long term i want the engine to have about 500hp. So i need a transmission that is good for that but still usable as a daily driver. Someone told me the 700 is what i should start with since it has the overdrive. But can i just bolt those on to a 350. I dont know how it all works. Any help would be muchly appreciated. Thanks!
12 bolt gears from large chev cars will fit in the truck rearend housing. You have to change the carrier also. For example 3 series gears such as a 355 wont fit a 4 series carrier such as a 410. We have a powerglide equipped 66 that we converted from 410,s to 308,s. The ring and pinion along with the carrier came from a 72 chev caprice.
Hello R. Fizer, for what it is worth, I was in the same situation with my 1966 C-10. It had a Turbo 350 behind the 327, and factory 3.73:1 gears in the rear. With 225/70R15 Dunlops all the way around, I was buzzing 3600rpm on the tach trying to keep up with traffic.
I put a 1992 spec 700R-4 automatic overdrive transmission in my truck, and switched to 245/60R15 BFG's. Made all the difference in the world. Now, in 4th gear(overdrive) with the torque converter locked up, I am turning 2300rpm at 55mph. Much better.
Seth K. Pyle
Nothing is sailor-proof...
1966 C-10 SWB 327 - 700R4
Story in 60-66 Parking Lot
3600 rpm doesn't sound right for that setup
ron
How did you deal with the overdrive problem? I have been told that ppl either hook it to a switch or make it so that it goes into overdrive as soon as you hit 3rd..
Apprentice
Apprentice
My 63 panel has that set up 350 w/700r4. There is a company that sells a small control box (for lack of better words) that allows the 700 to work like it's still in the original truck including an adapter at the speedo. The coolest thing with this box is that you can actually dial in the torque convereter since most of these trans were computer controlled
Thanks for the info! Do you perchance remember the company or anything that will allow me to find it?
Thanks again,
Rob
