2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | I am wondering if anyone is reproducing the lower drivers side cowl panel for the 47 trucks with the vent door in it, I've been looking with no success for one, mine is pretty well shot, is it something I'll have to fabricate or is there a commercially available part... Kevin
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | As far as I know they are not offered you may want to post an ad in the parts wanted section. I cut mine just below this point due to the lack of a replacement but it may require some additional grafting in your case. I cut up about a cab a month for parts so let me know if you want to go that way next time I get one I will save it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are able to salvage the outer panel with the vent door opening, the inner panel is available from Jim Carter.
| | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | Brad, If you could set one back next time you find one it'd be a huge help, Mine is a little too far gone to repair I believe, it is not only rusted but crumpled as well, so the odds of it ever fitting a new panel or working properly are slim. Kevin
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It is not unusual to find one or both cowls severely creased because people were in a habit of backing up with the door open (original mirrors are not very good). it catches on a post or equipment and it buckles the cowl almost in the middle where the door edge hits it. I will save one for you and contact you when I get one. | | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | Sounds good, thanks. Kevin
