3 members (GRNHydra, Wally / Montana, MRMEROTH11), 64 guests, and 3 robots.
Topics128,066
Posts1,055,876
Members48,428
#563851 08/10/2009 9:37 PM
Apprentice
Apprentice
I am wondering if anyone is reproducing the lower drivers side cowl panel for the 47 trucks with the vent door in it, I've been looking with no success for one, mine is pretty well shot, is it something I'll have to fabricate or is there a commercially available part...
If it's old and rusted out.... Well it's probably mine.
[http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url]
1978 Dodge W200/M880
2002 Dodge Ram 2500 Cummins Diesel
Photobucket Pix
Kissfan113 #564113 08/11/2009 7:39 PM
As far as I know they are not offered you may want to post an ad in the parts wanted section. I cut mine just below this point due to the lack of a replacement but it may require some additional grafting in your case. I cut up about a cab a month for parts so let me know if you want to go that way next time I get one I will save it.
Brad Allen #564167 08/11/2009 11:07 PM
If you are able to salvage the outer panel with the vent door opening, the inner panel is available from Jim Carter.
Brad Allen #564337 08/12/2009 1:48 PM
Apprentice
Apprentice
Brad,
If you could set one back next time you find one it'd be a huge help, Mine is a little too far gone to repair I believe, it is not only rusted but crumpled as well, so the odds of it ever fitting a new panel or working properly are slim.
Photobucket Pix
Kissfan113 #564342 08/12/2009 2:19 PM
It is not unusual to find one or both cowls severely creased because people were in a habit of backing up with the door open (original mirrors are not very good). it catches on a post or equipment and it buckles the cowl almost in the middle where the door edge hits it. I will save one for you and contact you when I get one.
Brad Allen #564388 08/12/2009 5:17 PM
Apprentice
Apprentice
Sounds good, thanks.
Photobucket Pix
