1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | This may be a minor problem, but it worries me a little. I installed the passenger side hub with no problem, but the drivers side seemed like the nut did not want to go on far enough. All the races are seated correctly, but when I put the spindle nut on with the washer and torqued it to 33 ft/lbs like the manual says, the nut was not onto the spindle as far as the passenger side. I had to put in a smaller diameter cotter key in order for it to fit. Any ideas why it wouldn't go on as far? I did tighten the nut as much as possible and back off again and retorque, but it didn't help. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Super55, double check that all the bearing races are fully seated, and make sure your spindle nuts are the same side to side. Did both sides have a dust shield at the back of the hub? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Bobb, they both have the dust shield and the nuts are the same. The difference may only be a quarter of a turn on the lock nut. It would probably line up, but would be too tight on the bearing. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | 55, You've got the right on the left or left on the right. I'm kidding. What was the situation when you took it apart ? I would measure the length of the spindle and hub to see if they are different, plus the distance between bearing races. If everything on both sides is the same then go to step B. I'll work on step B while you check that stuff. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | When I took the wheels off I didn't notice any problems. I think the outer bearings might be the difference. I will check them later. If I recall I had to get them from two different sources. I have a third set of bearings, but they are not barrel roller bearings like the other two, it is a tapered roller. Wonder is I should try installing that one. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I took the drum off again and put in the original wheel bearing. I also took a look at the dust shield. It was a bit out of line with from the contact surface and shield itself. I tapped it with a hammer to line it up the best I could, and I still had to put in a 3/32 cotter pin instead of the 1/8th. I think I am going to have to live with that. The bearing feels good, wheel turns nicely. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2009 Posts: 36 New Guy | | New Guy Joined: Aug 2009 Posts: 36 | Did you happen to notice if the washers are the same thickness?. Do you still have the cotter pin that you took out, perhaps it was smaller also. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Take the nut off, put it in a vise, and file the castle slots a little deeper. It's possible there's a burr, or just a manufacturing tolerance problem with one of the spindle nuts. Jerry
