2 members (fonz8261, Hotrod Lincoln), 122 guests, and 0 robots.
Topics128,113
Posts1,056,279
Members48,439
#563898 08/11/2009 12:34 AM
Just curious where the spring goes that returns the rod the joins the gas pedal to the carb goes. One end to the rod but not sure where the other end goes.
This is the spring that returns it to idle when the foot is taken off the gas pedal.
In the AD trucks, the rod to the carb and the rod that goes to the gas pedal attach to a plate that pivots. A spring goes from a hole in the pivot plate to a bracket that is mounted on the lip of the pan with one of the pan bolts.
1951 1 Ton Completed
That's the way I did mine. I just fabed a flat tab with a hole for the spring and the pan bolt. Bolt it on the pan and hook up your spring.
Some will just hook it on the lip of the pan, but I didn't like this approach. It's much more secure if you have something to hook the spring on.
George
46forme #564175 08/11/2009 11:47 PM
I just used a hardware store corner iron (or corner brace). Alreaday had 2 holes in it and was about the right size.
Harold Wilson
41 Chevy 3/4 Ton
Thanks for the help!
I needed a little more tension so I put one end of store bought spring through the cotter pin hole in the throttle rod at the bell crank and the other around the block drain petcock
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
