6 members (Jon G, baldeagle, Oswald, fonz8261, Hotrod Lincoln, 1 invisible), 55 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#555 12/16/2004 3:37 AM
Hi gang,
I'm tearing down a donor 292 cylinder head and want to really clean up the valves (which are in really good shape) and the bottom of the head. Is there any problem bead blasting these areas to remove all the years of baked on carbon and varnish?
Please advise???
Thanks, in advance!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#556 12/16/2004 4:20 AM
I cleaned mine with a wire cup brush and a scraper. Seemed to work fine.
[img]http://www.angelswest.com/_borders/headcrack.jpg[/img]
54 3100 with 235
62 flatbed dump C60 with 261
#557 12/16/2004 5:06 AM
H Online: Content
I beadblast valves all the time. If you're concerned with creating a rough surface on the valve stem, slip the part of the stem that runs in the valve guide into a piece of rubber tubing. (vacuum line, fuel line, etc.)
#558 12/16/2004 1:27 PM
I just lightly chuck the valve stem in a drill press and use a small screwdriver as a tool to clean the head like using a lathe,takes about 10 seconds.You can easily polish the stem and this way too.
#559 12/16/2004 5:08 PM
Slip a piece of hose over the stem and blast away. I wouldn't go with a lot of pressure. Leaving a rough surface it will cause problems because the carbon will stick to it better.
You could also soak them in lacquer thinner, it will soften up the varnish.
Fred
52 3600
69 C-10
#560 12/16/2004 5:19 PM
When I was at the machine shop we used the hot lye water solution to clean valve,rockers, etc, same things blocks went into. You can do it at home with a half a metal drum, some fire(gas or wood or charcoal) & lye or Drano, can be re-used, beware its corrosive to alum & your skin/eyes. (I'm not responsible for injury/alum damage, do this at your own risk,results may vary,buyer resposible for all taxes & license)Your local machine shop could also soak a 5 gallon bucket of parts pretty cheap, I know we did it for free if we did any machine work for folks. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#561 12/16/2004 5:32 PM
I blast with walnut shells....if you use glass PLEASE USE LOTTSA HOT WATER AND SOAP TO CLEAN EVERYTHING!!!!
I have seen people shell blast assembled heads and run em
But I can't do that
#562 12/16/2004 10:33 PM
Right on, Jim. Can't believe what I've seen people do. eek Maybe we should have a calender with
12 stupid things not to do to your truck.
Sure wouldn't be hard to gather the info.
Fred
52 3600
69 C-10
#563 12/17/2004 1:49 AM
Just called my local NAPA (which is a good store with a nice bunch of guys that WILL go the extra mile to find the old catalog stuff) and they quoted me $24 for a hot dip, rinse AND crack detection. I didn't think that was too bad cool cool
Burgie
#564 12/17/2004 4:15 AM
I'd go with the NAPA deal. If you figure your time is $25 an hour you'll come out way ahead plus know if they are usable.
