| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | Hey all,
I about have the interior of my '49 3/4 ton cleaned out and stripped down to nothing. I noticed some rust through in a couple of places (driver's side floor board seams, front driver's side exterior door support near the running board) and I am going to cut them out and replace them. Do I need to worry about bracing the cab with square tubing to keep things plumb and square before I cut out the sheet metal?
Thanks! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | hi Wyobolter...Firstly welcome. Is the cab still on the chassis,and are the cab mounts still in good order? It's generally regarded as a good idea to leave the cab on the chassis as it holds everything square and where it should be. Effectively using the chassis as a 'jig'. If it makes you feel better it wouldn't hurt to add some extra bracing in the door opening before you start 'surgery'. Anything you do to help the integrity of the cab has got to be good! IMO. Czechman... a fellow bolter has performed some pretty major surgery on his cab,he,if anyone would be able to give you some sound advice. You could try sending him a PM. I'm sure he could put your mind at ease! Hold tight as someone else will chime in with there 0.02c before long! Good luck Jock
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | Thanks Jock! The cab is still on the chassis, but it looks like the mounts will need to be replaced. I am thinking that I will probably brace the cab so I can take it off and replace the mounts without losing square.
Any suggestions on where it is best to brace? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Here's a link to Woody's (Czechmans) Home Page . I admit ,Thankfully I haven't had to resort to such extreme surgery,as my truck came from sunny So-Cal. I'm quite sure the other guys will chime in soon with some expert advice. I would assume bracing in diagonals,i.e. door openings. For example,lower left hinge area to upper right opening at the latch area and so on, would be best, but as I say,wait for more opinions......  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | WyoBolter,
Bracing does not guarantee anything. Keep the cab on the frame, do one part at a time and check door fits as you go and if the doors fit and the cab bolts to the frame that's all you need.
In your case just do one at a time and you'll be fine. Those are easy fixes.
| | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | Thanks Czech,
I want to shoot for a full body-off restoration especially so I can clean the frame and hit it with some POR 15 or other sealer. If bracing isn't a real guarantee, is it something that I need to worry about? Would it be best to fix those couple of areas and maintain the door fit and then pull the cab without bracing it? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Wyobolter...sorry to butt in.
If you fix areas of the cab to it's original state with the doors fitting well,you can safely remove the cab without any extra support. Just be sure to place it on a 'dolly' that replicates the original cab to chassis locations. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | No problem with butting in. The more information I get, the better I feel.
I think that is how I am going to fix the cab. Aside from a few (ha! more like a lot) mouse nests and tiny rust spots, the cab is in really good condition. I am going to start working on those patch areas this weekend. Thanks for all of the help Jock and Czech. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | WyoBolter...Welcome to the "BOLT"! What you are about to do is exactly what I did to my truck. Before I did any cutting to my cab, I braced everything with 1" angle iron, to help keep the integrity of the cab. As mentioned by the other bolters, and can't be stressed enough, do one area at a time and don't be in a hurry. There's a picture trail on my webshots if you'd like to see what I did. Also, I see you live in Gillette. You can swing by my house in Pine Haven and talk shop. My cab is almost completely finished as far as the panel replacements go (19 total new replacements). Good to see another Wyoming dude in here!
~Ron | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | WyoBolter...See! I told you someone would 'chime in' I read you've already got an invite from a fellow 'bolter mummdog,who from what I can gather is close to you. Ain't this site great!  Good luck and keep us posted on your progress. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | I just have to say that joining has been a big benefit. Between the tech tips and reading through the forums, I am definitely ready to get my bolt up and running fast.
Thank you again Jock and Czech. I have a definitive plan on how I am going to tackle these patches.
mummdog (Ron), I will absolutely take you up on your offer to stop by and talk shop. It would be great to see another Bolter's shop and get some good tips.
Thanks again everyone! | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | WyoBolter...I sent ya a PM with my contact info. | | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | Thanks Ron. I've got it. I will give you a call the next time I head that direction. | | |
