1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
I am replacing by 1939 Chevy 1/2 ton's rear end and front end with parts from a 1951 Chevy car. Will the wheel cylinders and or brake shoes from the 39 fit on the 51? I just replaced the cylinders and brake shoes less than a year ago.
3B Offline
Hy K9sicem, I can't find all the info I would like to have to confirm or deny what I'm going to say, the wheel cylinders do not have the same part numbers, or the same bore sizes. I think but I'm not positive that Chev switched from "huck" to "bendix" brakes in 51 across the marque. You may be able to install your cylinders and shoes to the backing plates, as both appear to be 11" brakes. However I would strongly recomend you rebuild the Bendix brakes and use them, as they are a much more efficient brake. You could always post your fresh wheel cylinders and parts in the for sale area to recoup some of your investment in them, hope that helps.
