1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#563583 08/09/2009 11:09 PM
Turn sigs are driving me nuts..all of the parts houses have diagrams/switches for a 6-wire system...my truck has a 3-wire to the switch (yel,lt.blue,dk. blue)..I've got a short to grd somewhere...
Does anyone have a wiring diagram for this???
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #563590 08/09/2009 11:30 PM
Riding in the Passing Lane
You will have to use separate turn lights & stop lights in the rear for that system. The yellow wire will go to the flasher & the blue wires to the corresponding turn signals.
1972 Chevy c10 Cheyenne Super
I know I need separate lights, but still need the wiring diagram..
Geoff
68 GMC 3800
try this, but you ahouldn't need it to find a short to ground, ya need a meter and some patience wink
Thanks Red58 for the diagram...I've got the meter and the patience, but needed the diagram to see where the junctions are..
Actually the problem is a ground loop as the rear lights are sealed, rubber mounted units and they work without being grounded..
and that shouldn't happen...
Geoff
68 GMC 3800
