1 members (Cosmo), 76 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#561142 08/01/2009 5:31 PM
I am looking at a a 1962 k20 it has a four shaft transfer case I thought these only had the 3 shaft 205? cases in them? Any help would be great. As i know pretty much nothing about older four wheel drives. Thanks Matthew
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
They all have the rockwell t-221 transfer case with 3 drive shafts. One of the shafts might be for a pto. I think the k-20s had that option.
1961 k-10
86 c-20
02 duramax
the fourth shaft would be coming from a pto, not for a pto but for whatever it has to drive. that means that it has a pto on it.
it should have a t221 unless someone upgraded it to something else
ron
normally the pto is run off the transmission do you have any pics
IIRC, the Timken 221 has provisions for 2 PTOs, one on each side. I'll have to check the manual to be certain on that. There is also a PTO on the drivers side.
Bill Burmeister
k10 Offline
Here's a slightly chipped one! But you get the idea.
http://images.google.com/images?gbv...21&aq=f&oq=&aqi=&start=0
4th one over, 2nd row
perhaps if there was a picture it would solve the confusion
ron
Thanks for all the help guys. I know this day and age i should have a way to put up pictures. But i dont . It looks like the pics K10 put a link too. On more question is this a good 4x4 to have behind a 350? I have read that they some times have a over heating issues? I am look at making this a daily driver. And it can get hot in Texas. Any help or other ideas is a great help. Matthew
1947 1Ton stepside
1962 K20 Fleetside
1963 C10 Stepside
1963 C20 Fleetside
no conclusion
ron
Did you get the pics I sent you Ron?
1947 1Ton stepside
1962 K20 Fleetside
1963 C10 Stepside
1963 C20 Fleetside
it is a T221 t/c. there are only 3 d/shafts coming from it. the small 4th shaft that you see protruding is a shifter rail.
ron
the T-221 is NOISY, it has straight cut gears...also, the output shafts are roller bearing supported which have a reputation for wearing fast and they run warm/hot. If it is in good shape, put some lucas oil stabilizer in it....it will reduce the temp, and some of the noise. They are just about as strong as a 205 if in good shape. Rebuild kits are still available.
64 & 66 GMC long fleetside 4x4
Cartwright, OK
