1 members (ShopRag), 63 guests, and 4 robots.
Topics128,024
Posts1,055,392
Members48,422
#563134 08/08/2009 4:37 AM
what modifications do I need to do to get my 216 gas pedal rod to work on the 235 in my 1946 1/2ton? It appears long but I just located this original equipment one today and would like some guidence before modifing?
geezy #563182 08/08/2009 12:40 PM
I was able to buy hookup components such as threaded rods and threaded swivels at NAPA. These components were apparently devoloped for "hot rodders" for use in custom installations You will need to envision what you need.
meansam
meansam #563201 08/08/2009 3:31 PM
If your 235 is a 1959 or earlier you won't need to modify anything, it will bolt right on. If it is a 1960-62 there are a few options.
My Blog
1956 engine and it does go right on, but will not connect to the pedal bracket.Could the pivoting arm on the block be backwards?
As the engine is in the rig,NAPA is looking better all the time.
Thanks for the help.
geezy #563267 08/08/2009 8:13 PM
There are two spots on a 56 235 for the throttle pivot. The front spot is in the same spot as the 216.
My Blog
Here'a a pic showing the stock linkage on a 55.1 -- the bellcrank pivot is in the forward hole, so the bellcrank is partially hidden by the exhaust outlet. Note that the rod from thew accelerator pedal pushes from the top, rotating the bellcrank ccw.
Here's a better view of the 55.1 linkage from the assembly manual.
Here's a pic showing a 62 235 with the bellcrank pivot in the aft hole. Note that it pushes from the bottom. I have no idea if this is stock for the late 235.
regards,
Leon
