3 members (latroca52, 2 invisible),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | found a guy that has taken off his 5 lug disc brake set up off his 1/2 ton will this work on my 3/4 ton or will i have to swap axles? Thanks Tom | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | You would need to change to a 1/2 ton axle for the parts to work. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | You can also put 1/2 ton spindles on your 3/4 ton axle by reaming the bushings to match your kinpin. | | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | Thanks I went to look at the parts last night. The brakes are still on the frt axle and everything looks new. He switched out to a Mustang 2 set up. He said when he hit a bump in the road the front end would shimmy some so I will need to check the tightness of the rod ends . I am hoping that the spring center pins on the 1/2 ton are the same as my 3/4 ton.If so I got a heck of a deal on a set of disc brakes. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | the infamous bump steer......
