2 members (Kilted54, UtahYork), 72 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
found a guy that has taken off his 5 lug disc brake set up off his 1/2 ton will this work on my 3/4 ton or will i have to swap axles? Thanks Tom
You would need to change to a 1/2 ton axle for the parts to work.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
You can also put 1/2 ton spindles on your 3/4 ton axle by
reaming the bushings to match your kinpin.
Steve
'49 3800
'52 3600
'57 3100
Thanks I went to look at the parts last night. The brakes are still on the frt axle and everything looks new. He switched out to a Mustang 2 set up. He said when he hit a bump in the road the front end would shimmy some so I will need to check the tightness of the rod ends . I am hoping that the spring center pins on the 1/2 ton are the same as my 3/4 ton.If so I got a heck of a deal on a set of disc brakes.
the infamous bump steer......
