7 members (Goach2, Dave1234, IHPWR, Hotrod Lincoln, TUTS 59, Peggy M, 1 invisible),
73
Mod | | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | Just installed 23560R15 BF Goodrich, on new disc brake conversion with tapered tie rods and new steering link bar. (Orig straight axle) Anyone have a process (documented) for a front end alignment at home in the garage? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can set the toe-in. Raise the front end & take an ice pick or awl. Support the awl with a jack stand or something that will hold it steady & put it up to the tread of the tire around the middle preferably on a continuous tread. Turn the wheel to scribe a mark on the tire all the way around. Do this to both wheels. Set the truck down & have someone hold the end of a tape on the line on the tire on the back side. Measure to the mark on the other tire. Do the same at the front of the tires. The front needs to be about 1/8 in less then the rear. Loosen the clamps & turn the tie rod to adjust it. That is the only adjustment you changed with the work you did. The camber is not adjustable on straight axles without elaborate Equipment & is seldom necessary. I don't know how to measure caster without alignment equipment. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | This makes sense but I would think that it assumes there are no bent wheels, correct? If there were it seems to me that would throw the measurement off if in the wrong position or am I missing something? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thats the reason for scribing the line. If the bearings & kingpins are good & you hold the scriber steady it will be even even if there is runout. I have a measure inst. that goes to the outside of the tires. I have to be shure there is no runout using that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I have a measure inst. that goes to the outside of the tires. I have to be shure there is no runout using that. Do you use a dial indicator, or something else? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its a log aluminum bar that has an adjustable slide on one end & a 90 degree bar on the other end. It is quick & can be done with one person. I usually roll the vehicle & check it in 2-3 different places to make sure there is no variation. I've had it for 30-40 years but they still sell them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | We use Wheel a Matic on our over the road trucks http://www.wheel-a-matic.com/ They are simple and have been around for over 50 years. Even if you don't buy any of the tools, you can learn a lot by looking at the various tools and reading the instructions. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like a neat setup for the home user or on vehicles with toe only settings. We use the Hunter Hawkeye in our shop.
Bill Burmeister | | |
