8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#561963 08/04/2009 7:34 AM
Apprentice
Apprentice
Is there a way to recreate the spot welds our trucks have in certain areas, I'm trying to make the truck as close to the appearance of new as possible, but this one has thrown me. all help is appreciated.
If it's old and rusted out.... Well it's probably mine.
[http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url]
1978 Dodge W200/M880
2002 Dodge Ram 2500 Cummins Diesel
Photobucket Pix
Kissfan113 #561985 08/04/2009 12:49 PM
tclederman #562442 08/06/2009 1:39 AM
Hi,
When I replace the cab corner, I made a Little holes with the driller as the same diameter as the original spot weld( not too depth) , once painted look very similar.
It is just my opinion, good luck
alfonso #562498 08/06/2009 4:28 AM
Check some of the other car restoration sites. I think you will get some tips there as well. I read on one site where the restorers were using a flat end punch with a back-up behind the joint to make an impression that was very close to what a spot weld looks like.
IMHO, unless you are going for points in a concourse showing, I think this level of restoration is a bit over the top. Just my opinion.
Just a though...but if you're trying to replicate the 'factory look' to this degree.
Why not hire a spot welder? ohwell
More pix on Flickr.
jockbolter50 #562622 08/06/2009 6:03 PM
The welder you are looking for starts at about $8000 for the real thing. It does a great job but real pricey for a do it yourselfer. Any good quality body shop should have a resistance welder if you wanted to pay for what you are looking for. You could just take a sharp drill bit with a flat cut and do it. I have done that before for the real picky customer until we bought the resistance welder. We have had about 10 years now and it does a great job.
48ton1/2wrckr #562644 08/06/2009 7:38 PM
I saw this on TV but I am not sure if it works well as far as looks go. They did plug welds to join the pieces and then ground the surface smooth. The final step was to use a blunt round punch to make dents that look like spot welds.
1951 1 Ton Completed
truckernix #562650 08/06/2009 7:51 PM
truckernix,
That is what we are doing on the 54 pickup I am restoring. The procedure is pretty well described/shown at the link I posted above.
Tim
Kissfan113 #562656 08/06/2009 8:01 PM
Check here or here.
Bruce
My Trucks
Stuff I Collect
