8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle), 106 guests, and 2 robots.
Topics128,179
Posts1,057,068
Members48,460
Apprentice
Apprentice
I have a 52 chevy 1/2 ton truck with everything stock in the back. How big of a tire can I put in the back (without having to do any mod). I just saw a truck just like mine with large slick tires in the back on stock height . It was really giving another dimension to the truck. I didn't have time to talk to the guy or take any picture.
What do you guys think ?
Do you have any pics ?
Let me know.
Peioa
Just a thought...Are you sure it wasn't tubbed?
Did you see inside the bed? Just seems strange someone would use slicks on relatively narrow wheels.
Sounds like it was a pro-streeter,were they standard width?
The height's not so much a problem,but width...... Here's one I found
More pix on Flickr.
If I remember correctly, the rear fender inside to bed side dimension is 11 1/2 inches.
I am planning on running a 265/75/16 tire, it has a 10 1/2 cross section. These will not be on stock wheels.
I have 255/70/15 tires on 15 x 8 rims with a 3 3/4" backspace and no interference issues. I could not find 16" rims with sufficient backspace that I liked but am satisfied as what I did buy is a direct bolt on without spacers, longer studs, etc.
http://good-times.webshots.com/photo/2563630450023244788GRGawV
You Tube
Curt...That sure is a 'purty' rear end!
(The truck,that is....) grin
Good info you've provided,especially the backspacing. This is the thing most people struggle with.
Is that the stock rear axle?
More pix on Flickr.
