1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I wonder how many of you have the drain on the lower left rear side of the engine on a 235 or 261 motor or is the hole filled with a sealed bolt(like mine). I'd like to hear your experiances with the drain and where you found it(parts supplier) as I've checked the usual chevy parts links and haven't found that drain with the metal piece through it any where.
I have a bolt in my motor block and it doesn't leak but wonder if I should get the parts and actually use that drain on the fire truck. Thoughts or ideas? Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've had engines with and without that drain fitting, not something that's used much - one should be available at a local parts place or rad shop, it's the same as the drain on most of the old radiators - it does as well to pull the plug you have and flush some water thru, sediment does tend to collect in the passages down there - or if you store the truck long term in the cold you can drain the block there to be safe against freezing
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is a 1/4 pipe thread plug. You can remove the plug & usually have to poke something in the hole to break the scale built up around it. It's a good way to drain & flush the system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks guys. Now I know what fits in the hole. I hope to find the part that matches the originial that came with the motor in 1951. I've been to several of the local parts stores but nobody has an originial.
I am getting ready to flush the system, so I'll clean out that area of the block while I'm at it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On '55 2nd and later, that style drain seems to only be found on the 235 used in the Forward Contol Chassis (box van), pickups and heavy trucks didn't have them according to the shop and assembly manuals.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Just to chime in,
On my recent rebuild of a 216, we replaced that drain-cock with a brass quarter-turn valve, (not sure what they're called, I call them "gas-style", 'cause you see them on gas lines sometimes). I hate the above-linked pet-cocks, even if they ARE original: I find them hard to use, I think they fail far too easily, and are prone to breaking off. Just my opinion, anyway.
During our install, we had to drain the coolant twice chasing down thermostat issues. We ran about a one-foot line from that valve, down past all the engine stuff. Now, when we need to drain the coolant, it's a simple matter of sticking a clean bucket under the drain-hose, opening the valve, and presto.
I know you're a stickler for originality, and good-on-ya' for it; but I know you drive that beautiful truck a lot, so I thought I'd offer this idea up. Let me know if you want pics, and I'll get some this week.
-Michael | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Lets see the picture! Thanks.
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill,
I bet you are right about that drain cock on later 235s. There were no drain cocks on the 1959 and 1960 261s that I worked on last summer. We put a drain cock in that existing threaded hole (because the engines were going into Advance-Design trucks).
Tim | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Tim,
Thanks. I guess that is why it has the bolt in it as it is a 59-62 motor. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Bill, Here are two shots of the drain-valve, as promised. Hard to see, but the hose curves back toward the engine and down between the engine baffle and the bell housing. Hope this helps you decide! -Michael | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. I have seen those type valves before. I'm going to hold out to see if I can find the originial version. I'm going to flush the systm anyway, so I'll pull the bolt and see what comes out from behind it!
Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike & Bill,
NAPA can get that valve - it's not cheap (Weatherhead-Eaton brass producs catalog). I am also using that valve as a shut-off in a fuel line before the fuel pump (in a 1954 truck that has no factory shut-off at the fuel tank outlet). It is an all-metal assembly, so there is no concern about rubber gasket/seal deterioration.
Tim
Sounds fine, I know it will look perfect when you're done. Look forward to seeing it.
-Michael | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill, If you are interested in an original-style drain cock that matches some I have found on old radiators and engines, Eaton (Weatherhead-Eaton) sells one, catalog number 6788 (1/4" male pipe thread). This one has a "snout" that allow a piece of tubing to be attached (makes for cleaner draining directly into a pail/container). Tim NAPA: WH 6788 Dorman sells a similar fitting: 480-245 | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'll check it out. Thanks. | | |
