2 members (Thomaslb, Eddie54), 166 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#561847 08/04/2009 1:58 AM
What is the correct way to install and attach the door glass channels in my 59? Do you install with screws or rivets? Keeping the window rolled up would work but probably get to hot.
Thanks ,
Brian M
originally there were metal tabs/clips that attached to the channel by pointy protrusions sticking out one direction that 'jammed' it into the space in the door, 4 of them - otherwise the shape and length keeps it in place .... if you're missing those clips, about all you can do is screw it on using very small flat head screws in the bottom of the channel, don't need many, mainly across the top and toward the top of the front and back to hold the curves, the bottom parts can't go anywhere
Bill, Thanks again. Used 4 small screws, two on top and two on side, just long enought to hold but not too long to hit other side. It wasn't easy but I'm happy with the result. I used a little glue to hold the end down in the door just to keep it from moving around.
Getting the glass and vent assembley in was much easier than I thought it was going to be. Took me about 1/2 hour to get it in and tightened up. My doors are off truck so I think that helped. The only problem is that the doors are about 30 pounds heavier with the glass.
Brian M
thumbs_up that's what I'm doin on daBus, which turns out to use the same felt channels as our trucks on the entry door and drivers window
yes, those doors are heavy assembled, but what I did to R&R one complete was find some blocks just the right height to set it on so the hinges were lined up and it wasn't much of a struggle to get them bolted up loose
