8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | I'm looking for a picture or information on how the weatherstrip retainer is positioned along bottom of door for my 59 1/2 ton. I've seen the pictures for the AD but was hoping to see one for the TF. Is there a specific location or is it centered in the door. I dont want to close the door to find out its on wrong. Im having a hard time seeing how this works. It almost looks like its the wrong one. Thanks, Brian M | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this help? there should be screw holes where the retainer goes [yes, centered], it squashes the seal some what into the corner against the pinch flange .... note there's also small clips at the corners Bill | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Bill, Thanks for the picture. It makes sense now. Unfortunately I have the wrong retainers. The tags say 55-59 but its different than what you show. I bought it from a company several months ago so I guess Im stuck with it. Maybe when I figure out what it is to I can sell them. Thanks Brian M | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brian - suprised a supplier would be listing an incorrect part - took a pic of a set of new ones I have just to be sure yours aren't right - if this isn't what you have [about 30" long, 6 slightly oval holes], maybe post a pic and ask 'what are these' in one of the forums Bill | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Bill, Thats not what I have. Mine are shaped like a "J" or an "L". They do have 6 oval holes and are around 31". Not sure how to post photos on this site. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like they're close, might need to try them upside down and downside up, or even modify them a bit - in the pic of my hand, they're in the position they'd go under the drivers door, the angle to the left pushes against the rubber, they're SS and the same dimensions as yours, maybe you could open the angle a bit to more of a V?.... if they're really wrong, might be 47-55, maybe even sold as 47-59, which would be wrong Bill | | |
