| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 31 | I'm sure this seems like a silly question to you old pro's out there but here it goes. Do I line up upper edge of beltline on upper cowel and rear panels to door? I'm guessing the pin stripe on door of my 52 accents lower edge of beltline on panels and not the actual lower edge of beltline on door? Hope that made sense!
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The beltline on the door should line up with the cab belt line. It's the most obvious visual and the most difficult to move so get that lined up and deal with any other fit issues after you accomplish that. | | | | | Joined: Jun 2009 Posts: 788 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 788 | Can you provide detail on the beltline stripe--proper size, color, and placement? I have a '48 Chevy 1/2 ton that is Forester Green. Thanks. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Don't remember where? but I once saw a photo that explained the belt line pin stripe location. It showed the bump where the wiper fastens. The pin stripe was on center of the shaft & followed along completely around the belt line. It looked like it was slightly down from the center of the belt line. But it looked right when it aligned itself with the front windshield belt area. Hope this help. | | |
