4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
Have a chance to buy a decent 1951 Dodge 1/2 T. but engine has cracked block. What are my options for a replacement engine? Are there other choices for direct bolt-in? I have worked primarily on Chevys in the past, need help with a Dodge.
Thanks for info--TK261
Riding in the Passing Lane
Any Dodge or ply. engine around that era will fit. I'm not sure of the exact coverage but it is very wide. The Desoto & Crys. engines are a litle longer but guys used to change them.
1972 Chevy c10 Cheyenne Super
Chrysler industrial engines will work too. I sold one out of a combine last year when scrap got so high. You can probably buy a whole car or just haul one for what the engine is worth. If its fluid drive, I think it had a different crankshaft flange.
Alot of tow motors and airline equipment used those motors too.
Wrenchbender Ret. got it right, I put a 59 plymouth in a 38 Dodge truck many years ago. Inliners.org has Mopar forum here's a post on industrial engines;
http://www.inliners.org/ubbthreads/ubbthreads.php?ubb=showthreaded&Number=48561
If the cracks not bad drive it.
LG
I don't own a vehicle that isn't old enough to drink.
On that Dodge-- My Father in Law had a 3/4 ton, and wanted more power. Look for a 6cyl Chrysler, to make it fit it was necessary to reverse the pan (to clear the axle) and the Oil pump. I wasn't there when he did it but it worked.
gene bryson
Where is the crack in your old engine? I have a 16" horizontal crack in my truck's original engine, probably caused by frost some winter long, long ago. It looks like it was welded around the time I was born, and the engine works well. Just a thought...
1951 3800
-hotshoe
