| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | I know there are some body parts that won't interchange between the light and medium duty trucks, but I don't know what all they are, any info would be a huge help. Thanks Kevin
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | What years are you referring to?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | the advance design series, i think it's 47-53
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | This has been covered before many times, a search may bring up the answers.
The short answer is: 1/2, 3/4, and 1 ton have the same sheet metal with exception of bed and running board lengths (which should be obvious).
1.5 and 2 ton trucks have identical sheet metal and only cabs and doors are the same between big and small trucks.
COE trucks are a different critter yet.
Hope that helps, Grigg | | |
