6 members (Hotrod Lincoln, Gray_Ghost, 1955 1 Series, 3 invisible), 323 guests, and 6 robots.
Topics128,156
Posts1,057,020
Members48,460
Hi guys,
My 1957 Pickup had a 327 V8 put into it a few years ago. The guy who put it in has since passed away, and I am trying to figure out where this engine came from.
There is a plate on the left side, just under the passenger valve cover. It is flat and looks a small extension of the block.
The only numbers that I can read stamped into this block are:
V062 HP
The HP is separate and is about 3/4 inch or so away from the other letters.
Does anyone have any ideas, or are there any other places that I can look to get the serial number off this motor?
It just looks like that front plate was stamped too softly. I've cleaned the area thoroughly, and all I can read is the V062 HP. It looks like there are some numbers before it, but I can't read any of them.
Should I take a light sand paper to it to see if I can get down to the metal?
Not too sure what to do . . .
Thanks to anyone who might be able to help on this . . . .
The engine serial number is stamped on the passenger side of the block, on a machined pad just ahead of the cylinder head. If you can get that number, that will help us figure out what it originally came from.
Bill Burmeister
That's the pad where I saw the numbers. I can't read the first few numbers, but the last ones are ....V062 HP.
3B Offline
Hy Joe VR, if you're sure it's a 327, then it's from a 1965,66,or 67 Corvette, if it is possibly a 350 it could be from a 1969 Chevelle with a manual trans, or a 1969 Chevrolet with a manual trans.
How do I tell if it is a 350? Are there any other identifying marks on it?
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
2003 Harley Davidson
There should be a block casting number on the bellhousing flange.
Bill Burmeister
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Hey Guys,
Here are the numbers that I was able to pull from the truck:
The numbers stamped on the front of the block (on the machined pad):
V026 HP
The numbers stamped on the back of the block:
3970010
The casting numbers look like it's a 1968 motor, but I can't tell anything from the V026 HP number.
Somebody told me that the HP stood for High Performance, instead of the regular passenger motor, but I can't find any more info online. Any additional help would be great.
Thanks guys!
-Joe
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
Casting #3970010 comes up as a 1969-1975 350, truck application according to the American V-8 Data Book. The HP code looks to come up as a 300 horse 4bbl 350, Chevelle, Camaro, Nova application. Might have been a case of a block shortage, so they used a truck casting to build a passenger spec engine.
Bill Burmeister
