3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,070
Posts1,055,900
Members48,429
#56051 02/04/2006 9:14 PM
I'm need'n to know about a part that I left out on my front end,it's the paper thin washers that sit on top of the bearing that the kingpin slides thru to conect the spindle to the upright?(I hope this makes since,kinda hard to explain without pix.)anyway I'm hope'n they are not an extremely
impotant part,but I'm sure they have a roll to play or they wouldnt have been in the kit,maybe just a cover for the ball bearings so they dont get dirt or debree in them?Just try"n to get some info to see if running with out the washers will be ok,I dread have'n to borrow a shop again to tear the frontend completely apart just to put two paper thin washers in.
1949 Styleline Special
1972 K5 Blazer
#56052 02/04/2006 10:40 PM
Riding in the Passing Lane
They are shims to take up any play up & down in the spindle. They go in the top of the axle with the thrust brg on the bottom. If you have a small amount of play it will be all right. If there is a lot of movement it will be nessesary to tear it down again.
1972 Chevy c10 Cheyenne Super
#56053 02/04/2006 11:16 PM
10-4,thanx for the info,hardly any slack at all so I'm gonna run it like it is for a while.thanx again!
1972 K5 Blazer
