| | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I found this 3 digit Code just above the firewall and below the hood seal. I have a 1957 3100 Chevy 1/2 truck. Does anyone know what this 832 code is for? Thanks! Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doesn't look like any kind of factory thing I've ever seen, the county's hidden ID marking? factory wouldn't put a tag under the seal, and they wouldn't tack weld it like that
Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Bill, I think I explained its location wrong. Its right above the back of the engine here on the firewall and along the top of the " lip " If you look at the second photo the number is at the top left of photo. Maybe it is just a unique number for the truck having been a county truck as you suggested. Thanks! jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I have the same type of tag on my '56 . Still not sure what it means. Ed | | |
