1 members (Hotrod Lincoln),
89
Mod | | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 21 | Some one once told me pushrod engines create more torque than non pushrod engines. When I asked why he dint know, can you tell me?
Yes this is my truck, No I wont help you move
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Odd Bolt, basically the longer the stroke the more torque an engine will produce, there are lots of other factors as well, but how the valves are actuated, by a pushrod/rocker arm setup, or overhead camshaft, doesn't contribute much to torque production, overhead camshaft engines generally have less internal friction, so more useable power is produced. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | What 3B said. Valve actuation has absolutely nothing to do with the amount of power an engine is capable of. The bore/stroke ratio and dimensions, valve timing, valve size, combustion chamber geometry, volumetric efficiency, fuel quality, fuel/spark map and state of tune are what determines the amount of torque and engine produces
| | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Back in the 50's some people referred to a overhead valve engine as a push rod engine. And of course the valve in head engines were more powerful than their L head predecessors. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's also not so much that pushrod engines make "more" torque, but that pushrod engines tend to make it at a much lower rpm band. As Scott pointed out, that comes more from the operating parameters, but there's also the consideration that in addition to being tuned to a higher rpm range, OHC engines also breathe much better, namely due to having more valves per cylinder. Which brings us to the L head and Overhead comaprison. Overhead valve engines breathe better than L head engines. The you have the F head, which is a comprimise.
Bill Burmeister | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | OHC engines also breathe much better, namely due to having more valves per cylinder
...when they do. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | more valves does not indicate better breathing. Combustion chamber and valve geometry determines that, whether it is 2 valves, or 5 valves per cylinder. intake tract geometry, valve shrouding, intake harmonics, engine exhaust scavenging etc. all determine engine breathing. If you want an engine to really breath, force feed the intake and suck out the exhaust.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Let me rephrase myself. OHC engines tend to have a more favorable valve layout, generally with a hemispherical combustion chamber. Intakes on one side, exhausts on the other. It has also been proven that multiple smaller valves will flow better that one large valve, another trait common to the OHC head layout. This also runs hand in hand with everything Scott said.
