| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56013 02/02/2006 11:22 PM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | Hello all,
Yes, I am a new guy to the site. I just bought a 66 C20 with a 250 I6. I couldn't make it run right and stay running, so I pulled the distributor and discovered about a mile of side ti side wobble in the distributor shaft! Are there any other compatible models of this unit in newer trucks, or am I stuck with this year? I just got a pertronix conversion for it, so the points will go bye bye anyway. Th carb leaks like a sieve so that will have to go, it's a Rochester 1 barrel with manual choke. Again, are there newer trucks with a two barrel manifold and carb I could use? Lastly, my bench seat is shot. Are the bolt patterns the same for Chevy trucks? I have several local junkyards to peruse if there are others that will fit. I don't have a show truck on my hands, just a good old work truck. Thanks for any help you can offer. Josh in Everett, WA | | |
#56014 02/02/2006 11:39 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Any dist. from 63-74 6-cyl. will fit. you can use the HEI from 75 up that is not computer controled but you already have the petronics. I would first try to o-haul the carb in their. They are simple & kits are cheap. 68 up single barrel carbs would fit with some slight modifications. You usually have to improvise to change seats but you can get some nice seats that way. A trim shop can rebuild yours or you can get a kit from the specialty suppliers & cover it yourself. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
