3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#558754 07/25/2009 12:37 PM
I recently picked up a 1947 towtruck,it had a newer 261 and that was all I was really after. The tranny I believe is a sm420 but it has a little lever on the shifter with linkage that runs right down along shifter into the top of the tranny.Is it some kind of tranny brake for engaging PTO? The tow truck winch would run in reverse according to the last owner, could have something to do with that?
Dustman #558762 07/25/2009 2:00 PM
You don't have an SM420, that's an earlier trans with a reverse lockout.
OldSub #558769 07/25/2009 2:29 PM
What kind of tow unit does it have on it. Factory, or Home-made?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
OldSub #558770 07/25/2009 2:33 PM
I think an early AD truck could have had that before the SM420 came out, so could it be the original transmission for the truck??
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #558774 07/25/2009 2:55 PM
I belive Grigg is right. That would be the correct transmisson for a '47.
1949 Chevy 6400
1931 Chevy Firetruck
I don't see that he says if its an Art Deco or Advance Design truck, but my experience is '47 trucks of both types have the crash box with the reverse lock release lever.
I've bought a couple of trucks called 48's that had that transmission, and the serial number always resolves to a '47.
OldSub #559544 07/28/2009 2:52 AM
I think that it is the original tranny.It is a home made wrecker. By reverse lockout do you mean the switch is used to put it in reverse and avoid doing so while driving?If it's not a sm420 does anyone know what it is? I've got a buddy that wanted it for his brothers jeep- maybe not if it isn't the 420 or is it just as good?
Dustman #559545 07/28/2009 2:54 AM
By the way thanks for all the previous info, it's nice to be able to find help these days
Dustman #559617 07/28/2009 5:22 AM
The reverse lockout prevents going into reverse unless you use the release, hopefully meaning you won't go there unless its intentional.
The SM in SM420 stands for Synchro Mesh. I don't know what the earlier transmission was called, I just call it crash box because it has no synchros and is hard to shift unless you double clutch.
It's not what your buddy wants for a Jeep.
OldSub #559895 07/29/2009 1:29 AM
Thanks alot for the help
Dustman #559910 07/29/2009 2:18 AM
I have a 1947 shop manual for the AD style truck and it shows the old style tranny.
1951 1 Ton Completed
