6 members (Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, Hotrod Lincoln, 1 invisible), 128 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#55975 02/02/2006 6:35 AM
i just got another 54 chevy standard shift. i want to put a automatice 54 rearend under it to get down the fwy a little faster. do i have to change the whole rear in out or is there a set of gears i can put in to change it that way ? i admit that this is a sedan this time around but it still does change my igorance any and i still could use the help please. thanks any one and all. tedjames
#55976 02/04/2006 2:52 AM
you need to swap the torque tube out of an automatic car.
#55977 02/04/2006 6:55 AM
1950-54 Power Glide 3.5 gears will fit in the stick housing. You will need to use the 3.5 carrier also.
My Blog
#55978 02/04/2006 7:01 AM
thanks for the help guys appreciate it alot tedjames
