| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55975 02/02/2006 6:35 AM | Joined: Sep 2004 Posts: 17 New Guy | | New Guy Joined: Sep 2004 Posts: 17 | i just got another 54 chevy standard shift. i want to put a automatice 54 rearend under it to get down the fwy a little faster. do i have to change the whole rear in out or is there a set of gears i can put in to change it that way ? i admit that this is a sedan this time around but it still does change my igorance any and i still could use the help please. thanks any one and all. tedjames | | |
#55976 02/04/2006 2:52 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | you need to swap the torque tube out of an automatic car. | | |
#55977 02/04/2006 6:55 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1950-54 Power Glide 3.5 gears will fit in the stick housing. You will need to use the 3.5 carrier also.
See the USA in your vintage Chevrolet! My Blog | | |
#55978 02/04/2006 7:01 AM | Joined: Sep 2004 Posts: 17 New Guy | | New Guy Joined: Sep 2004 Posts: 17 | thanks for the help guys appreciate it alot tedjames | | |
