| | | Forums66 Topics128,161 Posts1,056,957 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 57 | i am swapping a dana 60 front axle and a dana 80 rear axle from a 96 dodge onto a 1965 K20. i am also swapping the steering arm placement in the front to inside the frame and installing a power steering pump. i was wondering if 35" tires would fint and steer alright underneath. i wanted 33's but Kumho's new tire doesnt come in 33 and thats the tire i would really like to use. thanks Jonathan
Jonathan _____________ 1965 K20 project truck duramax swap 6speed tranny swap axle swap
1966 C20 camper special family heirloom restoration project
| | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I've seen 35's on a stock truck, they are tight but they are good for street driving. I imagine if you do any off roading they will rub a good bit.
1961 k-10 86 c-20 02 duramax
| | | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 57 | ok good, so 33's should work great. i was looking in a magazine and didnt see 33's for 18' rims in the kumho mud venture but i found them on tire rack. so i should be good running the 33's. thanks alot. Jonathan
