3 members (moparguy, 3B, Chip O),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | I installed my oil filter infront of the carb on the intake of my 1957 235 as that is where I thought it went. Looking at the 216s they have the oil filter behind the carb and the horn infront. My horn was mounted to the firewall. What is correct for these items on a 235? | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | The early filters went on the square center of the manifold where the intake and exhaust join. <CLICK> When the vacuum port got moved to that location the "normal" mounting location became forward of the carb.
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Oil filter behind carb., horn on firewall
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | agree on the filter behind, but it was an accessory item so might have been put anywhere the installer decided - never seen a TF with the horn on the firewall, all have been off the rad core support, single one behind and to the drivers side, or both sides w/ 2, that's what the louvers are for there, the horn mounts so the bell end is right behind them, as per the accessory manualBill | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I have a copy of Fram instructions showing the recommended installation procedure. I thought it covered up through the later years but it only shows through '41, all of which are where my picture shows. It's interesting that consensus is in favor of aft of the carb on later models because I've never seen one mounted there, only fwd of the carb. I guess in the end wherever the owner want's to put it is "correct".
| | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | Maybe I'll leave the horn out and get one of those bumper stickers that says, "HORN BROKEN, WATCH FOR MIDDLE FINGER" | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In 1953, Chevrolet was recommending that the automobile oil filter be installed forward from the carburetor. | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | I am sure you know this but make sure the oil line is no where close to the exhaust that happen to a 235 my dad had once . | | |
