My rebuilt '59 235 is installed in the truck and running smoothly.
Now for the bad news. I'm chasing leaks. Several of them! :mad: My initial reaction was a big let-down when I saw oil puddling under the rear main seal. Then I searched and read the posts on this site and I started looking more carefully. I'm still worried about the rear main seal, but it appears that at least some of the oil leak is coming through the valve cover gasket. I see traces of oil on both sides of the engine near the top. I guess this should not surprise me. The oil pump is delivering a lot of oil up top. So much so, I can't run the engine with the valve cover off, because oil squirts out the rockers and over the edge of the engine.
My question is, what should I do about the leaking valve cover gasket? The gasket is new and the cover is tightened down about as far as I feel comfortable (afraid of stripping the screws). I installed the gasket dry. Should I use silicone sealer on the gasket? Can I do this once the gasket is saturated with oil?
I also have leaks appearing under the tranny (SM420, 4 on the floor). I assume this is gear oil but I'm having a hard time telling the difference between engine oil and transmission fluid. The transmission was professionally re-built before the installation. I see plenty of oil way back at the universal joint. Maybe that is where the leak is coming from??
Which leads me to my second question. The universal joint (at the rear side of the transmission) has a separate fill-hole for gear oil. However, the shop manual seems to suggest that the universal joint receives its oil from the tranny. So which is it? Is there a separate reservoir of oil in the u-joint, or does the u-joint get all of its oil from the tranny? Is the torque tube seal at the universal joint a place where others are experiencing gear oil leaks?
Thanks! The help I've received from all of you has been priceless (in more ways than one!)
