| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I recently found a guy on Ebay that sells shop manuals and in cd format. http://cgi.ebay.com/ebaymotors/ws/e...tem=400061821485&_trksid=p2759.l1259My question is, has anyone ever dealt with him from this group? Just wanted some opinions before I drop $35 on a cd that may or may not work for me. Thanks everyone. Fred | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Why buy the CD? Just go to http://chevy.oldcarmanualproject.com/ when you want a digital image. I bought a CD for my tractor. The problem with that CD was it didn't have chapters. You had to scroll to find anything. By the way, I have the shop manual, build manual, and parts manual for my truck. The shop manual is an original, but the other two are reproductions. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Good information. I clicked on that link and that is a cool site. It had exactly what I was looking for. I will now however, look for a printed version as you suggest. Thanks a bunch for steering me in the right direction.
Fred | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | You can keep checking ebay and you might find originals, or you can get reprints from places like Jim Carter; http://www.oldchevytrucks.biz/47_55/full.asp?page=74 A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Sweet. Thanks for the info. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | One other question, I see a lot of Supplement manuals. What should I be looking at for finding the main shop manual? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | It's on there. Just look through the lists. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | So is it safe to say that the Master Shop manual is for a 1955 and just adding the 1956 supplemental manual for the 1956? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Yes..Hemmings is a good source for vendors with original manuals..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | Is there such resource for 1966 C60? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
