1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | This is dumb. I've wired my entire truck and only have one problem, the cigarette lighted assembly. It worked for awhile and now and then it blows a fuse. I traced the entire wiring back to the fuse panel and cannot see any problems or bare wires. Sometimes it works fine when pushing in the lighter, and then other times it blows a fuse. I have it grounded also. Seems like it may be how the lighter is pushed into the socket. Could that be the problem or possible a ground that is not good enough. Man, this is embarrassing. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | It sounds to me like the little clip inside the socket is holding onto the lighter element too well. You might try cleaning the raised edge around the end of the element with a scotch-brite pad. I don't know what you could use to clean the clip, maybe an emery board? The clip itself might need to be widened slightly(very slightly or it won't hold at all) (disclaimer)Be sure to remove the fuse before working on the socket.  | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | I'm with 54tow. If the wiring is good, the device is the likely culprit. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What size fuse are you using. A lighter takes a pretty good size, like 25 amp. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You say it worked once or more times. Must be something wrong with the lighter or as Wrechbender says check the amperage of the fuse.
~Jim
| | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Right now I am using a 20 amp fuse. I'' check the clip. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | I replaced the fuse with a 25 amp and it worked fine. I then disconnected the positive on the battery, tried pushing the lighter in again, and it blew the fuse on the next try. My friend thought he saw a spark at the dash where the lighter is connected but I'm not sure. I did notice the fuse light up and blow at the fuse panel. This thing works one minute and then not the next. Real fustrating. It may be the assembly is faulty, I may try and get a different one. This one is brand new from Advance Auto. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Messed with this thing again. Seems like it blows the fuse shortly after it works the first time. Could it be that since the element is still hot, that is what is causing the fuse to blow. Just a thought. You would think you could use it even if still hot. Could it be I need larger wire. Any thoughts.
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I notice you said that it was grounded. The only ground it should need would be through the dash itself. Is is possible that the socket has loosened? I would try to snug the back of the socket with pliers. If that doesn't do it - it's probably just bad. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | The socket has a electrical tab for the hot wire and there is another tab that I assumed was for a ground wire. At least, thats how I wired it up. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Might not be related....BUT, on my 91 s10 blazer it has the lighter and the remote release for the back glass all on the same circuit as the dome lite. long story short is it would blow a fuse every so often and then got worse. lived with it,only real inconvenience was no remote to open the rear glass. finally got around to messin with it and the lighter sockets grip prongs,where it contacts the element were shorting to ground,but not all the time! Regards Steve Sr.
| | | | | Joined: May 2009 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 99 | If you used too small of gage wire, it could do this. Pull the fuse out and disconnect the lighter terminal and check continuity of the wire, to ensure there is no short-to-ground (should be 0). With the wire off the lighter terminal and the lighter element out, check the continuity of the lighter terminal-to-lighter case (should be 0). If thats all ok, you could try checking the lighter element. It should have a certain amount of resistance. I just don't know how much that is. You could also try a lighter element from another vehicle, if you could find one that fits. If none of this points to the problem, its an attitude thing and we all know attitude things can be fixed with real big hammers
Dave.
What's the last thing a red neck says, "Hey guys watch this." What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Take out the whole unit, hook up ohm meter (continuity check) one lead to hot terminal and other to the ground term if it has one. this should show continuity. Then touch the same lead all around the unit as you plug lighter in and out of socket. you will probably see continuity while touching some place on the unit (this means it's shorting). you can temporarily insulate various areas down inside till it stops shorting (tape or paper). remember, take it out of dash, socket and lighter and work on bench (wood bench!) there are other ways to check continuity using light pen etc. But it's best to use a method where no power is applied to unit. get a cheap multimeter. Bartamos
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Finally got the cigarette lighter assembly to work. I took the original purchased one (Made in China) and bought a different one (Still made in China) and hooked it up. I also rewired the original wire to make sure the wire size was the same all the way through and now it works fine. I guess the original was bad. | | |
