10 members (MNSmith, TexasJim50, Hotrod Lincoln, 39Master85, Otto Skorzeny, MarkT, 1955 1 Series, ronsway, tclederman, Snowman51), 94 guests, and 4 robots.
Topics128,164
Posts1,056,978
Members48,458
#559170 07/26/2009 11:31 PM
i am swapping a dana 60 front axle and a dana 80 rear axle from a 96 dodge onto a 1965 K20. i am also swapping the steering arm placement in the front to inside the frame and installing a power steering pump. i was wondering if 35" tires would fint and steer alright underneath. i wanted 33's but Kumho's new tire doesnt come in 33 and thats the tire i would really like to use. thanks
Jonathan
Jonathan
_____________
1965 K20 project truck
duramax swap
6speed tranny swap
axle swap
1966 C20 camper special
family heirloom
restoration project
I've seen 35's on a stock truck, they are tight but they are good for street driving. I imagine if you do any off roading they will rub a good bit.
1961 k-10
86 c-20
02 duramax
ok good, so 33's should work great. i was looking in a magazine and didnt see 33's for 18' rims in the kumho mud venture but i found them on tire rack. so i should be good running the 33's. thanks alot.
Jonathan
Jonathan
_____________
duramax swap
6speed tranny swap
axle swap
family heirloom
restoration project
No problem.
1961 k-10
86 c-20
02 duramax
