5 members (DadsFirstPickup, 1955 1 Series, Jon G, Joe H, 68ironhead), 123 guests, and 4 robots.
Topics128,078
Posts1,056,046
Members48,433
#558932 07/26/2009 2:52 AM
I have just installed a rear axle from a s10 into my 1950 3100 pick-up,I have found that the ebrake cables are to long. Is there a way to shorten these cables to work properly? Do I need to buy shorter cables? What would be the best option?
Thanks in advance.
Yes,
Go to your FLAPS or NAPA and ask for cable shortners. They are a trianglar shaped part that you tighten a screw down and it draws in the cable which makes the cable shorter. You may meed 2 per side I wan to say they take up a max of 1 1/2".
They run about $3-4.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
John...Not the cheapest option but I used these.
I am pleased with the quality,they were easy to fit and look pretty good too!
If you really want to 'splash the cash' you can get them with stainless braided outer sleeves.
More pix on Flickr.
That Lokar discription leaves a little to be desired Scotty. Don't see how those would attach to the AD backing plates with out a bracket and it sure isn't clear how they can be cut to length.
We installed a replacement from one of the popular vintage vendors and they too leave a lot to be desired over the original cables. They could actually be a little bit longer than they are, they just barley made it to the forged frame brackets.
DG
Denny G
Sandwich, IL
Denny...I never mentioned they would fit an AD backplate,as I noticed John1950 was using an S10 rear end.
I'm quite sure a call to Lokars Tech Dept might throw up some solutions.....
As far as cutting to length, the conduits are pretty straight forward and the cables are cut at the 'front end' and attached to the front clevis with the long hex sleeve. It secures to the cable by 2 heavy grub screws.
Seems to work fine in mine,and I need a fully functioning parking brake for the UK M.O.T test (annual inspection)
I agree it's always better to use OEM parts where possible but in my case that wasn't an option.As I mentioned I am more than happy.....
Jock.
More pix on Flickr.
I get custom cables made by Tewco Inc. in Franklin Wisconsin.
Missed that Scotty, thought he was addressing an AD.
Thanks Mr. Danforth, I bookmarked the site, never heard of them before. May just use them in the future.
Denny G
Sandwich, IL
i made this swage, cable stop cause ya gotta have one of them to hold the cable at the frame.
out of a grade 8 - 5/16'' x4'' bolt, threaded it longer, drilled a hole after cutting off the head and crimped it to my new rear end cable ebrake. Crimping is critucal and i did a three crimp job. i heated the swage red hot and used a special crimper so the in-dented swage was bonded to the inner cable itself in three locations. painted silver.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan7_0007.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan9_0009.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan8_0008.jpg
and heated them red hot to crimp them in three spots like
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=4495365-R1-028-12A_1-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=4495365-R1-024-10A_1.jpg
available as S/S; marine supply sailboat
http://www.bosunsupplies.com/rigging_quickattach.cfm
http://www.bosunsupplies.com/products2.cfm?product=S0731
Jim & Caroline
They are a retail outlet for cable craft cables (industrial). If there is a cable craft or tuthill dealer in your area, check with them as they can provide the same service. I havent bought any in the last 3-4 years, however they were very reasonable.
Thanks Scott, I'll keep that in mind.
Jim that is a great idea, never thought about doing that. In the case of the e-cables that we got for the 3100, it was the housing that was just a bit short, it just barley made it to the bracket. I ya figure out a way to make a "get bigger" for the housings, let us know.
DG
Denny G
Sandwich, IL
in fact Denny there is
as you look at the photo notice a cable stop. this could be made longer. this holds the outer housing to the truck frame. since i installed a 77 4x4 rear end [12bolt] my cables were too long. same solution can be used, if ya got a lathe. as you view the photo see the spacer that looks like a 3/8x2'' sleeve. this could be made 3/8'' -7/16'' dia up to the truck pinch bolt. the lip is to help hold the rubber boot from slidding off. this sleeve is drilled thru for the cable. the end where the cable fit inside the sleeve about 5/16+/-'' to locate the outer housing and keep the dust out. i used the old rubber cable cover to add w/ dust inside the inner.
you can also lube [white spray lithium grease] the inner cable once a yr/ or 3 using a motorcycle cable lube applicator. place a rag at the brake shoe side as the grease will squirt thru. those should always work better and not rust out.
https://www.slipstreamperformance.com.au/store/images/CLBDUO.jpg
Jim & Caroline
