2 members (Roxxstar, 1955 1 Series), 298 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Junior Member
Junior Member
Our stovebolt editor thought there might be someone on this forum that could help. I'm trying to re-locate the gas tank to under bed between rails in back. I don't want the filler neck in wooden bed. I've seen guys put them through flat sheet metal of box. But I'm trying to avoid C-notching the frame. Any body been down this road before and if so I'd sure like to hear from you.
bluenoser,
I did a relocated tank on my truck. It is a 4400 with a 12' flatbed...big rails sitting on the frame and lots of room...should have been easy. It was a [censored].
My tank top was even with the top of the factory frame rail. This creates a "no drop" situation for the fuel filler.
I ended up putting the fill through the rails on the bed, and even then the drop was marginal.
I even contemplated using the factory fill through the cab and running it out the back and into the tank..too funky!
There are nice hatch covers available to mount in the bed of the truck. They have some made of aluminum with neat fasteners, and they compliment the bed area. If I had to do it again, I would use one of these items. They look nice, they are functional, and they get the job done.
Stuart
Apprentice
Apprentice
1 Offline
Dah What year? Why do you want to relocate? There hasnt been a case of a gas tank exploding in the cab. if it catches fire it burns to the outside. Try an S-10 tank.
1bad58
1bad58,,,my.02
I dont think most guys relo the tank for that reason,but more for a practical purpose such as being a big guy weight or heightwise.
Know of 2 diff gents that moved the tank,
1 bacause he was 6ft4 grin
1 because he was 300 plus :p
Both loved their trucks and wouldnt think of gettin rid o them wink
By moving the tank you gain that extra depth by moving the seat rails back,
Its not much but sometimes an inch is alot eek
Regards
I put an aftermarket tank between the rails of my '55 1/2-ton. For the filler, I had a piece made that mounted to the inside of the driver's side bedside (facing inward) and fab'd a filler tube that used rubber slip tube on each end. Not the easiest solution, but it avoided having to put the filler in the bed wood or use an awful gas "door" on the fender.
I saw a website that I found a link for on this site where the owner put the tank along the passanger side frame rail. He then cut a hole in the rear fender and welded in a gas door and box kit, installed the filler neck there and ran it down to the tank. It looked pretty nice when it was done.
I had a tank inside the passenger side frame on 46 for many years. Used the stock filler sticking out of the cab, cut off the filler tube and welded on an elbow and ran that pipe down through the floor to new tank. I had trouble filling this tank and finally got tired of this and went back to original tank, but probably could have fixed the vent problem.
1946 1/2-Ton Chevy
try:
http://www.stovebolt.com/bboard/cgi...d=results&record=2453776-190328-3GGJ
Topic Date Forum
1955 1st Series C100 04 February, 2006 General Truck Talk
Need advise- thought it would be easier 31 January, 2006 Paint and Body Shop
I'm stuck and need advise on 1950 -3100 31 January, 2006 The Engine & Driveline Shop
moved the tank - but what about filler neck 30 January, 2006 General Truck Talk
Underbed gas tanks 27 January, 2006 General Truck Talk
gmc 49 or 50? 26 January, 2006 General Truck Talk
Gas tank ???? 19 January, 2006 The HiPo Shop
Correct height of 48 1/2 chevy bed 17 January, 2006 Making a Stovebolt Bed
Side Mount Spare Carrier 17 January, 2006 Paint and Body Shop
Simple Advice to Anyone w/rusty gas tank 11 January, 2006 General Truck Talk
under bed gas tank 17 November, 2005 General Truck Talk
aftermarket underbed gas tank 17 November, 2005 The HiPo Shop
factory under bed tank 13 November, 2005 General Truck Talk
gas tank under bed 16 October, 2005 General Truck Talk
On the road, sort off 26 August, 2005 General Truck Talk
looking for gas tank under the bed or beer keg gas tank 02 August, 2005 Truck Parts Wanted
What EXACTLY will work as a gas tank under the bed? 500 bucks for a new one! =heck no 01 August, 2005 The Engine & Driveline Shop
Exhaust System Options 29 July, 2005 The HiPo Shop
235 having trouble starting 25 July, 2005 The Engine & Driveline Shop
under bed gas tank from LMC how to install 03 July, 2005 General Truck Talk
Jim & Caroline
