8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
Hello everyone!
I used the search engine thoroughly to try and find the size and number oil filter for my 1953 GMC pickup....Another user gave me a Wix number but the number didnt match the system numbers....If anyone could please give me the number for a Fram, Purolator, Wix, etc. oil filter so i can get it back in there, I would be most appreciative!!
Thank you all,
53 GMC
"If it can't be fixed with a hammer and duct tape, God doesn't want you to have it"
1953 GMC Truck
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I appreciate your help jfnar! However, I only saw where it dicussed the oil canisters but not the size oil filter with regard to Fram, Purolator, or Wix numbers for the actual oil filter. I have the Oil filter canister, not the oil filter however. A guy in advance auto told me his dad used to use toilet paper rolls with holes cut in it- needless to say i will not be doing that! haha Any help would be most appreciated!
53GMC : )
1953 GMC Truck
Don't laugh at the toilet paper idea. It was a fairly common practice. Don't know about todays TP though. Find a real filter.
A lot of vendors carry them. Measure the inside of the cannister and go to the "links" page here on the 'Bolt. Pick a parts vendor and start looking. It shouldn't be hard to match one up. Good luck.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
53GMC, not sure if you found a filter yet but here are some WIX filter numbers with description and dimensions. First number is height, second is ID and third is OD in inches. CLM=Cartridge Lube Metal Canister:
51100 Cadillac (51-58), GM Cars/Trucks (50-62), Clark, Hercules, CLM 5.007 4.094 .553
51121 Buick (53-58), Cadillac (57-58), Chev.Trucks (56-59), CLM 6.339 3.778 1.095
51143 GM Family of Cars/Trucks (58-67) CLM 5.777 3.594 1.281
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
I have been through this but the guy at Carquest came up with the right filter for me. You should measure the diameter of the inside tube, the diameter of the case and the height from where the bottom taper ends to the top. It is important the the filter inside tube seals are the exact size of your tube. You need the an OD of the filter that will fit in the case and a height that uses most of the can. Do a Google search for a filter site with cross references and look at the specs given. You can pic a filter from that.
My filter is a Carquest 85100.
1951 1 Ton Completed
C Online: Content
Assuming we are talking the old filter in the external oil filter cannistersetup, try NAPA's Gold #1100
Craig
Hey thanks truckernix and cmayna! Those really helped a great deal! Probably will be asking more questions like that in the future!
1953 GMC Truck
