4 members (BC59, Goach2, 2 invisible), 90 guests, and 2 robots.
Topics128,092
Posts1,056,457
Members48,443
#55809 01/31/2006 5:11 AM
I was just reading about a restoration, in Classic Car. The engine rebuilder in the article does not tank blocks any more. Instead, he hangs them in an oven at 600 deg and then when they are cool, removes the ash and shot peens them. Has anyone heard of this before?
1951 1 Ton Completed
truckernix,
My wife does that every night at dinner time!
Stu-the-ash-eater
#55811 01/31/2006 12:39 PM
Fred,I just wired a Sunnen engine cleaning system at the local auto machine shop.
The cast iron,block heads,whatever, is heated to around 800 degrees F,all the grease and water jacket deposits and rust is vaporized.Then an after burner incinerates the debris to 2600 degrees,only a hand full of dust left.Then the block is put in another machine if necessary,stainless shot is fired at the block,low velocity,not like a sandblaster,to clean any remaining crud.The iron parts look like the day they were cast.
These two machines cost about the same as a new 4x4 truck,but the shop doesn't have the hassles of all the nasty chemicals and disposal of those chemicals.
Tony,
this must be the way of the future. The article I was reading involved one of those horrible AMC aluminum blocks so I guess the temperature was a little lower.
Fred
Junior Member
Junior Member
Sounds better than using the old dishwasher.
first time i heard of cleaning a motor like that....
1966 Chevrolet C-10
1971 Chevrolet Camaro RS
1989 Pontiac Bonneville
MY GARAGE...www.dragcitygarage.com
I still like using the mother-in-law's tooth brush, I just got remember to get back to the bathroom when I am done :-)
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
Pretty good Cujo. That's right up there with using her chapstick to sooth the cat's butt.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
I
I Offline
I'm currently installing shot blasting machines to clean up the parts. Sand blasting is ok, but its slow. I can out a block or head in this machine and 10 min later I get one back that just need to blown off or machined and painted. The reason some are baking the blocks is because of the waste. Ash can put straight into most landfills, sludge from a tank cleaner cant. It has to go hazardous very expendive to get rid of. One of my machines is a horizontal and the other is a vertical blaster. When i get everything running and up to speed, I will offer this service to others in our area. Imagine, brake drums,heads, tranny cases, blocks,manifolds, and a host of other parts, just as clean as the day there were casted.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
