1 members (Brian Moore), 95 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#557756 07/22/2009 5:01 PM
I
I Offline
Just got my truck running (YES! drive!!) and put some brake fluid in, to test her around the house. Tried to stop her but no luck headscratch. Pump on the brakes a couple of times and could feel some pressure but no enough. So pulled her back into the garage and checked my brake fluid , NONE. So I pulled the brakes apart and notice the wheel cylinder is missing what looks like a plug on one side. Could this be my problem. Its a 1953 GMC 3/4
1953 GMC 3/4-Ton
In Photobucket
In the wind, til the end
iceman1985 #557760 07/22/2009 5:11 PM
You should be able to tell where the brake fluid is leaking. If not you need to add more fluid and bleed the brakes. If it is that dry I would expect some leaks and other problems.
iceman1985 #557771 07/22/2009 6:21 PM
I
I Offline
thanks for the advice
1953 GMC 3/4-Ton
In Photobucket
