5 members (Bill Hanlon, Southerntruck, UtahYork, 55shaker, FAST55), 78 guests, and 4 robots.
Topics128,056
Posts1,055,804
#557616 07/22/2009 12:41 AM
Hello truckers, Is the turn signal switch the same for a 1966 C-60 and a pickup of the same vintage and /or does anyone repair them? Mine works to the right but not to the left unless you hold the lever up. Also the brake light does not work on the left side though the light flashes when the 4 way flasher is turn on. I am also curious about the sun visors and heater knobs/levers. Someone robbed my truck of these item a short time ago.
3B Offline
Hy wiltrek, as far as I know the turn signal switches are the same, the brake light functions pass through the turn signal switch, and the four way flashers are probably not wired through the turn signal switch. Check out the links to the various suppliers, hope that helps
3B #557634 07/22/2009 2:41 AM
38 is right, the 4ways have their own flasher..I used to have a 66..you can get a new switch at most any parts house..have you pulled the left rear bulb and checked for voltage when brake applied??
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Stick #557921 07/23/2009 2:25 AM
The turn signal switch can be bought new at napa, carquest the signal stat was the emergency flasher and im not sure you can get that new. As far as the heater levers knobs go you can get them from lmc or any aftermarket place or try rj sisneros on here in parts. Also the switch is the same as the pickups.
