1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 9 New Guy | | New Guy Joined: May 2009 Posts: 9 | Hello truckers, Is the turn signal switch the same for a 1966 C-60 and a pickup of the same vintage and /or does anyone repair them? Mine works to the right but not to the left unless you hold the lever up. Also the brake light does not work on the left side though the light flashes when the 4 way flasher is turn on. I am also curious about the sun visors and heater knobs/levers. Someone robbed my truck of these item a short time ago.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wiltrek, as far as I know the turn signal switches are the same, the brake light functions pass through the turn signal switch, and the four way flashers are probably not wired through the turn signal switch. Check out the links to the various suppliers, hope that helps | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | 38 is right, the 4ways have their own flasher..I used to have a 66..you can get a new switch at most any parts house..have you pulled the left rear bulb and checked for voltage when brake applied??
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | The turn signal switch can be bought new at napa, carquest the signal stat was the emergency flasher and im not sure you can get that new. As far as the heater levers knobs go you can get them from lmc or any aftermarket place or try rj sisneros on here in parts. Also the switch is the same as the pickups. | | |
